ALOT of Performance and Stock PARTS
sullen
Senior Daydreamer
Gotta clear out some crap.
Everything is plus shipping!
Everything is plus 3% for paypal!
DRAGLITES:
The Draglites are in mint condition 15x8 rear with nitto DRs and 15x7 fronts with BFG comp ta.
The tires are in decent shape too. I'll take 800$ or best offer for them.
If you don't want the tires, I can use them and lower the price for just the 4 wheels.
GTA'S
The GTAs are non-dimpled, 2 fronts + 2 rears, theyre in "driver" condition...
the centers were spray painted with black and clearcoat, don't look terrible, but not show quality.
Could stand to be refinished, but would probably look okay on an original paint GN.
Trans am centercaps and spacers for the rears are included.
I'll take 200$ for them.
GRAY UPPER DOOR PANELS - MANUAL WINDOWS
Good shape - 50$
BURGUNDY UPPER AND LOWER PANELS COMPLETE WITH ESTRUCHENS AND PULL STAPS
NON-concert cound lowers, only thing missing is the pull strap screw covers,
these are in really really nice shape - 150$
GN GRAY B-PILLAR TRIM
Top of Drivers side a little scratched (surface scratches, will look mint resprayed)
Otherwise all others are in average condition - 25$
JL AUDIO 3.5" SPEAKERS
Like new, NOTE: will require some mods to fit under the speaker plate of a Buick.
I only played these for about 10mins to decide btw this and another speaker.
Model: TR350-CXi, soldered a wire onto one terminal, otherwise like new. 50$
SCANMASTER SHADE HOOD
From TR Customs, new and sealed, this is a plain black version w/ no engraving.
AUTOGAGE MONSTER MEMORY TACH WITH SHIFT LITE
Model # 233906 - New in box 120$
FRONT BRAKES - ROTORS AND PADS, OFF MY LOW MILE GN
I don't think these are the originals, the car stopped very well with these.
Mechanic even called when i was having my SSBC setup installed
and asked why I was changing them out and asked if I wanted to leave them.
Stock size, the rotors look like new, plenty left on the pads.
Don't know what to ask for these? 100$ OBO
GN CONSOLE
Complete with plate, ashtray, door. Small crack in front corner that sits under the radio,
highly doubt this will be noticeable when installed.
Otherwise this is in very nice shape - 100$
PTC TORQUE CONVERTER
PTC 10" 2800 stall lockup. This is brand new still in box.
Changed plans so won't be using it. 525$
CONSOLE GAUGE POD
GN Gray, excellent to mint condition, don't think it was ever installed. 20$
SMOKED TURN SIGNAL COVERS
Used for one day, light scraches, 10$ Shipped
14" x 3" INLET K&N FILTER
This is banged up from the ac lines, not pretty but gets the job done.
Good for someone on a budget. 5$
STOCK UP PIPE WITH ALKY NOZZLE
Pipe in decent shape, nozzle has less than 100 miles on it. 30$
BSTC BOOST CONTROLLER + NOS WASTGATE SOLENOID + CASPERS WGS SPLITTER
This is a plug n play package for using the BSTC at high boost levels, provided you have a working solenoid.
BSTC Used but mint condition, Solenoid and Splitter new and in packaging. 200$ and im not splitting this package.
NOS COOLANT TANK
40$
STOCK BOOST LINES (2)
One new & one used. used 10$ new 20$
TURBO TO HEADER GASKET
For a 3bolt (stock style) setup. 5$
KIRBAN PCV & VALVE COVER GROMMET PACKAGE
New in packaging - 5$
RAIL MOUNT FP GAUGE
The one kirban sells, used for a month then went to an electric - 20$
CHROME FUEL PRESSURE REGULATOR LINE
Kirban product, new in packaging - 5$
2004R SUPERIOR SUPER SERVO
Used but in excellent condition - 100$
85mm Z06 MAF SENSOR
Delphi product. This is the big 5pin sensor for 4" setups. 80$
3" SILICONE HOSE
Connector hose, few inches long, thick silicone, from fullthrottle, brand new 5$
12' OF JL AUDIO 4G AMP WIRE
Was a 15' piece, cut a little off, about 12' maybe a little more remains.
This stuff aint cheap, I think I paid 25$ for 15'.. 10$
CK PERFORMANCE SHIFT KIT
The one on his site, the recalibration kit #24RSRK/A. New with paperwork 120$
FRONT DRIVERS SIDE NOS GM BUMPER FILLER
No, I dont have the passengers side too. 100$
STOCK CHARCOAL FUEL VAPOR CANISTER
20$ OBO
STOCK ROCKER SHAFTS
Nice condition - 25$
2004R PAN GASKET
5$
STOCK STARTER AND ALTERNATOR
Best REASONABLE Offer, no i wont take 5$ shipped as i can use them as spares
240 AMP ALTERNATOR
Stock appearing, the one Jack and the "other" board sells. 225$
STOCK TURBO SHIELD
Decent shape. 25$
CASPERS KNOCK GAUGES
Have 2, both are black face/black bezel, both in excellent condition. 50$ Each
MSBC-1 BOOST CONTROLLER
New in box, I'm not sure I want to sell this, so make an offer close to what it costs new if you want it, I'll move a few bucks on it.
FEL-PRO ES74022 HEAD BOLTS
New sealed box. 20$
QUAD AIR MODDED ECM
86/87 ECM modded by Red Armstrong for use with big injectors. 200$
STOCK CROSSOVER PIPE
Best offer. IDK what it's worth.
GRAY DASH SURROUND
The peice that goes around the instrument cluster, just dirty, good shape, 30$
NOS UPPER RADIATOR HOSE
20$
USED CLEAN UPPER RADIATOR HOSE
10$
COMPETITION ENGINEERING ADJUSTABLE DRAG SHOCKS
Part # C2600 - FRONTS - New in box - 75$ for both
KYB GAS-A-JUST SHOCKS
USED in great shape. Set of 4, came off my low mile GN - 75$
RACETRONIX FUEL PUMP HOPTWIRE KIT
New 40$
RACETRONIX DUAL FAN WIRING KIT
New 60$
MOROSO TRANSMISSION COOLER
Model # 41200, New in box. Cool looking piece. 70$
THREE 160 DEGREE THERMOSTATS
All used, IDK if they still work. 5$ each, ill send ya a refund minus shipping if they don't work.
(FOUR) 2 BAR MAP SENSORS
All OEM GM used sensors. Same terms as 160tst's! 5$ each
OEM 2004R TRANSMISSION PAN
Very clean. 30$
BIG BAG OF TRANSMISSION SEALS AND GASKETS
I have no idea wtf is in here, 10$
KENNE BELL OIL PRESSURE BOOSTER PLATE
Appears to be new, comes with paperwork. 10$
OEM FRONT PASSENGER DOOR ESTRUCHEN
NOS :eek: 50$
POWER STEERING BOTTLE
used, no cap. 10$OBO
WASTEGATE SOLENOID
Used. 25$
STOCK OIL COOLER PLATE AND LINES
Best reasonable offer.
HURST LINE LOCK
New in box, I think it's all there. price tag was 125$ Best reasonable offer
TWO STOCK TURBO OIL DRAINS
Appear to be in good condition. 10$ each
OIL FILL TUBE CHROME CAP
Nice chrome cap for the car still with the stock oil fill tube. 15$
GRAY REAR SEATBELTS
Clean and good shape - Best offer
EXTERNAL TRANSMISSSION COOLER WITH ELECTRIC FAN
IDK who made this, looks like a nice piece, looks new also. 100$
GN TRANSMISSION GOVERNOR
NOS - AC Delco # 8655976 - 125$
KICK PANEL TRIM
Both sides, nice shape, 10$
ok, GTAs are pending as I made this post.
if he falls through, will go to whoever's first.
both wheel sets prefer local NJ sale on.
parts
Can you pm me? I need to ask you some question about some parts you have here. Thanks.
New 40$
Shipped Price? If this is still in sealed package I'll take it.
DRAGLITES:
GTA'S
Good shape - 50$
GN CONSOLE
CONSOLE GAUGE POD
NOS COOLANT TANK
40$
RAIL MOUNT FP GAUGE
85mm Z06 MAF SENSOR
3" SILICONE HOSE
20$ OBO
STOCK ROCKER SHAFTS
2004R PAN GASKET
5$
240 AMP ALTERNATOR
STOCK TURBO SHIELD
Decent shape. 25$
New sealed box. 20$
QUAD AIR MODDED ECM
GRAY DASH SURROUND
20$
10$
New 40$
New 60$
Very clean. 30$
NOS :eek: 50$
WASTEGATE SOLENOID
Used. 25$
HURST LINE LOCK
GRAY REAR SEATBELTS
KICK PANEL TRIM
Want: 2 bar map sensor, 1 thermostat, turbo gasket, pvc package, F.P gauge, hot wire kit, chrome line, amp line, turbo shield, and 1 knock gauge!! Let me know!!!!!! :D
New 40$
well not sealed, it's in a ziplock bag with racetronix sticker on it, has been opened before, but all the wiring/realys are still new however, has never been on a car and is all still clean as new, the bag on the otherhand is a little dirty.
im going to be shipping everything via USPS Priority, using the flatrate boxes.
that ones good for the 5$ box so 45 shipped.
if you want, i can send ya pics?
just pm me your email.
thanks!
I will take one of the Casper's knock gauges and I am intertested in the crossover. PM sent. Thanks
i think the guy above inquired on the hotwire kit first..... just trying to be fair here.
ill gather everything and see which box i can get it in and get ya a total with shipping, paypal?
by pvc package, you mean the "KIRBAN PCV & VALVE COVER GROMMET PACKAGE" right?
and by amp line you mean the wire?
No problem!! didn't see it until i hit submit. ;) Yes, the Kirban. Ok, just let me know. Tried to pm but couldn't. Donnie.....
Sry...yes wire kit? Right? my add was kickin in. lol. And also, paypal.
I'll take....
and
Pm shipping details & paypal info.....
pmd for paypal info..
PM'd ya.
Fuel Pressure gauge sold.
usetaboost, let me know if you want the hotwiring, or want to check out a pic.
neck, everything else you wanted beside the hotwiring youre first in line for.
steve, ill check prior sales for crozzovers and PM you a price, youre first in line for the other knock gauge and crossover if you want them though.
im going to be going out in a bit, ill be able to get back on for a short time later but not enough time to really do much, so ill reply to everyone in the morning. ill be fair with PM and post times in the thread for who wants what.
thanks guys!
paul
thanks!
45 is good. pm or email me your payment info. I will send you a MO if that's ok.
interested in the 10 inch lockup Whats the part number on it? shipping to 49120.
