SignUp Now!Originally posted by Two Lane
Thanks for the clarification!
As with any pre-release product, there's always some amount of confusion circling around about it.
I stood in the rain with a dozen others just to get a good look
at the block at BG.
There's definitely a lot of interest---me included!![]()
Originally posted by Nick Micale
The block should be finished the machine operations in about 2 weeks. It will then go to Ken D. for assembly. It most likely will be tested there on the dyno. Will probably use the old M&A heads and stock intake with good 3.8 internals. The initial testing will probably not be for max horsepower readings, but for relaibility and compatability.
Block no.2 will be starting machine operations shortly after no. 1 machining is done. When short block assembly is verified, casting for the first run will commence. About one-half of the first run is already commited to people that have sent their deposits.
Design refinements to the old M&A head design are behind schedule but should be done in a couple weeks. It will then go into the casting process.
The M&A valve covers have been re-designed for better gasket retention, less posibility of leaks, and are now available for sale. These have "Buick" and the power 6 logo on them.
Design studies and flow tests are being done for a stock-type replacement intake. Not expected to see production before next summer. This is showing great promise of being much better than a ported stock intake or a worked Bowling Green one.
Cranks and rods are being looked at for replacement parts. Problem here is the large quantities the manufacturers require do to tooling costs, make the dollar investment very large.
Will post updates as it happens!
Originally posted by rking
I was wondering what type of oiling system will have to be run on these aluminum blocks. I know that it was said that stock parts will work on this block, so I am assuming that the block is going to be a wet sump. Right?? Or will a dry sump system have to be run on them like most stage 2 blocks.
