- Nov 24, 2001
i purchased a early 80's regal core support about 4 months ago from a board member, and it looks VERY close to the stock steel one-
the only real differences that i can see is area where:
1. the headlight wires go thru is smaller{ but the headlights are still 2 inches away}
2. the hood latch cable mount is a plastic i-let instead of the metal tab on the stock steel
3. it needs 2 holes drilled to mount the header panel 3 1/2 inch long bolts to the core support
i have a spare header panel, and both core supports laying on the floor just checking things out before i decide to tear into the car and do the install-
ALL holes look to be the same, except where the radiator rubber mounts go at the bottom of the core support- but its getting a aftermarket radiator, so it needs to be altered anyways-
so, the moral of this story is that i cant believe there isnt a huge difference between the 2.. my aluminum core support does not have the A stamped on the passenger side top portion-
i also WEIGHED BOTH core supports-
the ALUMINUM ONE weighs in at 13.0 LBS
and the STEEL core support weighs in at 30.0 LBS
thats alot of work for just 17LBS off the front, but i guess every little bit makes a huge difference in the long run-
