The exhaust didn't on the ones I've seen flowed though they came right up with light work.I love my TA heads and I believe they will flow better then your irons right out the box
.View attachment 274358
SignUp Now!The exhaust didn't on the ones I've seen flowed though they came right up with light work.I love my TA heads and I believe they will flow better then your irons right out the box
You have to be really stupid or stubborn to run iron modified stock heads in the low 9's, much less into the 8's.![]()
The internet is full of BS and opinions stated as facts, and this thread has many replies that prove this point?
HP is made by fuel and air, so the more air you can get into the combustion chamber, the more power you can make.
Since boost is restriction, less is better since compressing air quickly adds lots of heat which is not wanted in the combustion process.
The fact is alum heads have considerably larger ports and valves, more air can be moved and it will be cooler when entering the combustion chamber because of less boost.
Alum heads also dissipate heat better than iron heads, you can use more boost or compression than iron heads. All modern performance engines run alum heads with high compression compared the old muscle cars.
As far as pricing, that is more BS, max ported iron heads done right will cost about $1500, a set of new TA alum heads out-of-the-box with little clean up will out flow the irons by 50%. Basic cost of a complete set of TA heads is $1800.
Good flowing heads is the cheapest HP you can purchase!
One other BS statement on alum heads is they do not respond well in street driving. We have replaced many iron heads with alum, and NEVER seen any drop in street performance, just the contrary.
Of all the performance mods on our turbo cars, alum heads is an item that in most all cases will add value to the car because it is visible proof, not someone's sales pitch about their iron heads that my be ported with larger valves or not!
There is no doubt that aluminum heads are better, but at what point? Will it help a car that runs 10.8s with a 6262? Not really, and there is probably a place where the money could be better spent.
you should of switched to aluminum heads at the 12.0 levelWow!
That is where the TA alum heads far outshine and flow much better than iron heads as only minimal porting is needed on the exhaust side.
When the design for the TA heads was under way, Kenny D. did some flow bench work, and helped on the redesign of these heads which resulted in improved flow, especially on the exhaust side.
Well this isn't an apples to apples comparison, but my best time was 11.88 at 113 with an stock long and TE44. I was talked into getting Champion Ported Heads, with the same setup as before and my best run was an 11.92 at 115. I was trapping a mile or two higher with ported heads, but no improvement in my et. I was on gnttype.org at the time this was taking place and several people there told me ported irons or GN1 without a better CAM or higher rocker ratio was a waste of money. That I should have invested my money else where.you should of switched to aluminum heads at the 12.0 level![]()
Over 15 years ago we demonstrated the performance improvement of alum vs. worked iron heads.
A local car with a TA-49 and a few other mods was very consistent at the 12.0 level. NHRA then allowed car to run at 11.50 w/o a roll bar and the owner wanted to easily run at that level.
We installed a set of Champion GN-1's with no porting and no others changes to the car, it ran a 11.50 the first time at the track!
After selling his iron heads, this proved to be a very in-expensive way to immediately gain 1/2 a second in performance, especially for a mainly street car.
