turbocliff
I Slang in my white T
- Jul 5, 2004
Question for you guys with AMS1000.... My question is in regards to the scramble feature. If you set up the scramble for lets say to add 2psi... and have the input from a momentary switch, will it "stack" 2psi each time to activate the switch? Or would it add the 2psi the first time you hit the switch, then back the 2psi out the second time you hit the switch?
