SignUp Now!Welding will get easier as you go. When filling weld spots to make smooth I used this" all metal "filler that eastwood sells.. I bought it at a local body supply co.
I'd loose the flux-core wire and go with gas (Co2/Argon mix) w/.023 or .030 wire. You can rent a bottle from your local supplier. Flux-core wire requires heat that will cause problems with warping thin (< 1/8" gauge sheet metal) not to mention blowing holes. Of course first you'll have to see if your Welder can do both.
Yup that's the area I'm talking about. Where the Plate is for the body mount up in the corner. You wanna leave that alone. There is also the lip for the lower pillar plate in that area as well.
When fitting the floorpan in you'll need to make sure that you can re-attach the bolts from the cross-brace to the plate that's on the bottom of the tunnel.
That brace and the Seat belt anchor are spot welded to the panel. If you don't have a source for others you'll need to drill the spot welds out, remove them, clean em up and re-weld them to you new pan first. If your existing floor isn't rotted up the tunnel you might get away with leaving them but with any pic's it's hard to say.
You don't need to mess with the Inner rocker. Once you get the seat braces out you'll see the spot welds on the rocker side. There are also braces coming off the Inner Rocker underneath. They sorta cradle the Floor Pan. Those have spot welds too.
Lastly one of the reasons there isn't a complete write up on replacing these pans (that I can find and boy have I looked) is that it's a PITA.
Chevys and other cars from this era the pans came in two or four pieces, splitting the toe and floor-board.
Greg
