I developed an annoying ticking sound that starts at 2,200 rpm and get quieter around 3,000 rpm last year. I removed the serpentine belt with no change. From the drivers seat it seems to be coming from behind the gauge cluster, I disconnected the speedo cable with no change. It sounds like loud injectors or maybe coming from the valve train. Will lifters make this kind of sound ? I read in a post a while back where the OP was having issues with the rocker shaft bolts loosening up so I am thinking about removing the valve covers to make sure they haven't, but other than that I am getting lost. Has anyone ever had a similar issue ? Thanks, Kyle.
