Well i pulled the motor this evening and if we were panning for gold we would be rich. I pulled all the main caps and the crank looks really good for all the bearing materal in the pan. I only pulled one rod and it also looked good but the bearings were starting to show some copper. From the looks of things i may find a rod journal that is shot when i pull the rest. My engine builder says he can have the crank sent out and have the thrust metalized with some sort of powerdized metal procedure. Anyone ever had this done !!! If the crank checks out other than the thrust this would be a lot better than balancing a different crank.
