Those braces were on the car when I purchased it, along with neat seat braces,
Yours is different than mine... Did he make more than one design?Yes,the one you have is the new design. His is the old one. Jim Bell went from the old,bigger design to the new smaller design because it worked better. It has more efficient cooling fins. I've run this intercooler for at least 10 years.10.70s @128 mph. Spend your money on something else.
This last post peaked my interest, so I went through my paperwork and found my old material. Kenne Bell had these three intercoolers in his catalogue at the same time. Check it out. They all had different applications. Mine was called a Stage 4 Big Boy, while Quick6'n'-K.C. has the Big Boy Air to Air model.
Your intercooler is refered to as "Big Boy Intercooler".Stage 4 Big Boy is the name they called there T4B Turbo. The intercooler they marketed as"Dual Stage Intercooler air to air and air to water" was two "Big Boy air to air" intercoolers welded together. The fist air to air was exposed to air and cooled the boost pressure dramatically. Then the,already,cooled air entered the secound "Big Boy air to air" intercooler,which was encased in a water-tight jacket that had Ice Cold water flowing through it. The theory was,why waste a finite supply of cold water to cool down a very hot intake charge? Why not ,first,use the infinite supply of free air to cool down the intake charge,then send the,much cooler,air into a secound "Big Boy air to air" intercooler encased in ice cold water? Jim De Allesandro used this same Kenne-Bell "Dual Stage Intercooler air to air and water to water" to make 1,300+hp. and run in the 7's in the 90's.Kenne Bell had these three intercoolers in his catalogue at the same time. Check it out. They all had different applications. Mine was called a Stage 4 Big Boy, while Quick6'n'-K.C. has the Big Boy Air to Air model.
Cool. Thanks for the info. I was hoping someone would know what the deal was.
Bryan, have a question for you about the IC. Eventhough it is a front mount it seems to only block half of the radiator. Do you find that because of this the car runs stock temperatures? Or does it run a little hotter than with a stock location unit?
Thanks Jason
