jasjamz
THS Racer
- Sep 30, 2004
Pin hole coolant leak in the intake port. Very slow loss of coolant and not enough to make any tailpipe smoke and hard to see on a coolant pressure test depending on the size of the leak. Remove ALL the plugs and leave a pressure tester on it for a few hours. Kill the fuel and spark have someone spin the motor. If you get sprayed... you found your problem.
Speaking from experience.
