Any One Use These M15 Injection Nozzles From Mc Master Car??
Allen Vos
Hi there
Ive been reccomended the M15 injection nozzle from mcmaster car
part # 3178K77 , for my setup.
I wish to install this into my charge pipe(3" steel) right before the throttle
body.
Does anyone know what fittings are involved in doing this????
Im just not sure how to go about installing this nozzle in the pipe
Allen
youll need an 1/8 npt (coupling or elbow if you like), you can get fittings with various ends but youll need 1/8npt to thread the nozzle into
drill a 3/8 hole i think might be a little smaller so use whatever size it takes to get the threads to push through the pipe
put a small washer with sealer onto the nozzle and from inside of pipe push threads through hole
1/8 npt fitting screws on nozzle threads from outside using a wrench on nozzle and fitting to put some squish on washer
connecting your feed line to the coupling may need an adapter depending on your hose config or fitting you used
Have someone weld in a 1/4 to 1/8npt coupler into the uppipe.
