1984 t-type
Murphy's Law
- Jul 11, 2010
SignUp Now!did you purchase that extra piece needed for the tach?I have it it works great.
I wired it directly to harness
Read out is easy to see for boost also have fuel pressure reading in other display
Yes I used the DD provided speed sensorAny one using the Dakota digital Speedometer setup instead of the stock one?
Yes I had to purchase the filter to get the proper tach signal to work with displaydid you purchase that extra piece needed for the tach?
Once you have the base unit. All the additional sensors and units can be added at any timeThat's awesome. I also plan to get the $700 range one since I don't mind using my boost gauge I have now. Thanks for info and sharing pics. Looks good
And wired the ecm output and adjusted the output to proper output for the ecm
Works great
The signal speed output for ecm is switchable in the options selectionOk so how did you get that to Work since the company provided sensor runs on a different signal speed?
Thanks again for all the feedback. Don't be surprised if you get a PM from me if I struggle with install. Lol. J/k, I'm typically decent at something like this.Once you have the base unit. All the additional sensors and units can be added at any time
Works great
he posted pics on the first page in this threadYou have any pics of your dash?
This is confusing. I get it now. You mean the actual "digital" version oppose to the analog version?Was looking for digital Dakota dash pics. I thought that is what bobs84ttype had
