Anyone else have this happen?
ravege
Guess this happens often enough where there are extractor kits available, still.... :mad:
You could contact a professional tool vendor (I got mine from Matco) for an extractor kit.
pacecarta on firechasers PC
be gentle and spin it backward with a pick . 9 out of ten it spins out
Also try a small head magnet and use that with the pick got many out that way!
Happened so many times with my old stock posi, I was buying the pins in bags of 10.
If you have compressed air available I have been lucky and blown air at the bottom of the bolt through the pin and had it pop up.
I had a rear end that had the same situation. Chopp39 here came with a special drill bit that's made for this kind of stuff and drilled it and used an easy out. it took about 3 mins.
Prasad
