Hahny
- Jun 24, 2017
I would like to know if anyone is running a Walbro 255 on E85 and what would be the maximum HP with this set-up? Thanks
SignUp Now!Friend of mine has. As for as max power that will very car to car.I would like to know if anyone is running a Walbro 255 on E85 and what would be the maximum HP with this set-up? Thanks
On stock fuel lines?I ran 11.60 in a full weight GN with a 255 pump
Damn 28 pounds of boost and no knock...sweetThe E-85 in South Florida is mostly E-75. I have been running it for years @ 28# Of boost no knock 21degrees timing
Have you zeroed out the timing to ethanol content section?I'm running an SD2 chip with a flex fuel sensor so it adjusts timing and boost based on ethanol content
Sent from my XT1650 using Tapatalk
No. I decreased the amount of boost it was adding but otherwise the ethanol tables were left as deliveredHave you zeroed out the timing to ethanol content section?I'm running an SD2 chip with a flex fuel sensor so it adjusts timing and boost based on ethanol content
I would zero that out unless you like adding 4-6* of timingNo. I decreased the amount of boost it was adding but otherwise the ethanol tables were left as delivered
Yeah, I'm around 95% at 20 lbs of boost. I'm currently running 60 lb injectors along with a walbro 255 and was hoping to keep those when I convert over to E85, but you recommend 80's?With a 255 pump I would really like to know what your duty cycle is like at 20plus lbs of boost. I can almost guarantee it’s above 95%. If anyone was replacing a fuel pump and know they are going to run e85 I would look a the walbro 450 or a detuchworks pump . I guess it’s just me and not like running on te hairy edge of something goin south . Also you it would be wise to go with at bare minimum 80lbs hr injectiors .
The ethanol can handle the increased timing.I would zero that out unless you like adding 4-6* of timingNo. I decreased the amount of boost it was adding but otherwise the ethanol tables were left as delivered
