Precision makes the water and oil lines in a kit ... you tap into the throttle body coolant lines and run the other line where the factory oil line was and you keep the factory oil filter .... thats what i did
youll need a new oil feedline. you can get a good one from fullthrottle. As for the water lines I just went to my local speed shop and picked up some radiator hose and tapped the throttle body lines. No turbo saver and it seems to work fine for me.
Got an alternative to the usual oil feed setups. Just put it up on the site today. Obviously the stock oil feed port needs to be plugged.TURBO PROTECTOR KIT
