More fuel! More fuel! Start rich and lean it out, instead of lean and working towards rich
. Hi Mike, glad to have finally met you in person in Columbus (beard, glasses, lots of questions at the end of Sunday
). The rule-of-thumb is that you need a thread depth as deep as the diameter of the fastener to achieve a thread strength equal to the yield strength of the bolt, assuming equal strength materials on both threads. In this case the stud will be probably 3-4x stronger than the cast iron so for a 1/2" stud you would need 1.5-2" of thread engagement (which is long enough that the rule-of-thumb probably isn't very accurate any more, sigh). That also means that going to a stronger 7/16" stud may not help if the thread depth in the block is becoming the limit instead of the stud material. Having less than perfect threads from the leftover 7/16" threads will make this a little weaker, so again, get all the depth you can. What kind of thread depth can you get in the block? If it's much less than an inch, which I think unlikely, I'd be concerned about thread quality, but if it's over an inch I'd say diameter trumps depth. It's been awhile since I've gone through the calcs but if you compare the 7/16 and 1/2" threads you get one less thread per inch but the spiral has a larger diameter and and the thread surface is wider so if you unwind both of them you get more contact area with the 1/2" thread and so even at the same thread engagement depth it's stronger.
Anyway, just some thoughts.
