Ok a gentle correction
Not to get off topic, or that it really matters here. I do have significant experience with diesel engine combustion and controls and emissions research and am compelled to state- diesel combustion is
not detonation. Repeat, not detonation.
Diesel begins to
burn (ie combust normally) as soon as the fuel being sprayed into the chamber full of hot air (above the self ignition temperature of the fuel) dissipates far enough in among all the hot air in the chamber to get
lean enough areas to begin to burn. And a large area of the spreading fuel front begins to do so initially.
So in the diesel an entire chamber full of very hot air is there just waiting for fuel to begin combusting; for the spark engine, a tiny spark point source is all that starts the burn going. Huge difference in what initiates the combustion and more importantly here, how much begins to burn initially.
After the flame starts the combustion is basically the same- a normal burning of the air fuel mix until the fuel is all consumed. It is
not spontaneously "exploding" in uncontrolled manner, as in detonation.
It
sounds like it detonates in many diesel engines at idle for example because the rapid pressure rise from the diesel combustion does "hammer" the parts more than a spark ignition. Since so much more fuel begins to burn initially, diesel pressure rise in the cylinder is initially
much faster than spark ignition.
It is this rapid pressure rise that causes the audible hammering sound, the clattering.
The diesel parts are generally much beefier to handle this rapid pressure rise "hammering". The rapid pressure rise is
similar to what also occurs from detonation, but again, this is
not because of detonation.
A few things to note that help here; you could get the same audible hammmering in a gasoline engine if you had say, 50 spark plugs in the chamber all going off at once instead of just one. So now instead of a tiny spark kernel evolving steadily into a fireball, we get a big fireball intially. Then the pressure rise would also be very rapid, just like a diesel, but again it would not be from detonation. Hope that make sense about the rapid pressure rise..
And 2), you can make the diesel audible hammering sound
go away entirely by using a relatively new techique called pilot injection. Suddenly, your diesel is as quiet at idle as a gasoline engine. VW, M-B, some domestic trucks with common rail injection systems, all can vouch for this.
All pilot injection does is spread the heat release rate out some by injecting a tiny "pilot" portion of the main fuel pulse a bit early. Thus the overall heat release rate is spread out some, softening the pressure curve rise, and the audible hammering stops. But note that it is still 100% diesel combustion. This should prove to even the most die hard skeptic that diesel is not detonation.
We worked with a major euro OEM on pilot injection at SwRI in the mid/late 90's. We always had real time cylinder pressure monitor gear in place (with analog scopes) on the dyno test engines and could simutaneously
watch the pressure curve change and
hear the results in real time as we tweaked the fueling parameters. The difference is dramatic- Clatter-clatter-clatter at idle becomes dead silence. Is that thing still running?
Very instructive to be able to do this, as one can imagine.
Ok, apologies for the detour here, back to the real thread. A very good thread too, again thanks Mike for feeding those of us starving for some serious tech
Flame me privately please to help keep this great thread going in its intended direction.
TurboTR
