- May 27, 2001
Repeating my similar question from another thread...
Will the ISAC give me the ability to "flip a switch" and go from 15# boost to 25# boost with a mostly stock engine (Razor's alky kit, fuel pump, hotwire kit, injectors, chip, AFPR, etc.) with stock turbo, downpipe, internal wastegate, etc.?
Ira
Flip a switch, no. Turn a knob, yes.
You can use the trim knob on the front of the unit to control boost, boost ramp rate, AF ratio or alcohol control. You can also load different configs quickly to change boost levels if you wanted to go that route.
