SignUp Now!short answer= nope.
I'm going to respectively disagree. If I'm intrepeting his signature correctly, he has an upgraded fuel pump. I have always heard the the injectors and fuel pump were marginal in capacity. I'm a firm believer that you need more fuel capacity than you think you may ever need. I say go with the 36#'ers and chip. We all have a lot of money in our motors and having surplus (within reason) fuel system capacity just seems to be a good thing to me.
Conrad
ps...If you haven't already, put in a fresh fuel filter and replace all those rubber fuel & vacuum/boost lines with fresh hoses.
If you are going to spend money, spend it so you don't have to again for a long time. The 60# injectors work fine with a stock car and leave tons of room for bigger turbo's later.
I would agree with most though, if it is going to remain stock and you are not maxing out the stockers, why bother. They make plenty of power.
I thought the factory injectors didn't work well with today's fuels?
Forgot where I read that.![]()
is 17 lbs. of boost with stock injectors OK ?
You could always just get your stockers cleaned and flow matched. After 23 years a cleaning can't hurt.
