Brer Rabbit
Pursuit Specialist
- Feb 5, 2005
Should I wire brush the threaded parts of the studs to remove the black oxide finish.
SignUp Now!Just the fine threads where the nuts are pulling on them.
Funny... everywhere I've read says otherwise (Headstud installation article). Even so I don't believe this step is necessary. I did not grind off the coating on mine and I'm not getting leakage. I asked my friends who build engines and at my local machine shop and they said they never heard of people doing this. I also created a thread on this site asking why people do it, assuming it was because the sealant would bond to the threads better with bare metal ,and nobody seemed to know for sure why it is done... I think the most critical part is making sure the threads are clean, on the block and the stud, and using a good teflon sealant like loctite 567.
Luke
I don't do nothing to mine. But clean the holes in block and make they don't have any antifreeze or oil on them then put silicone on threads and screw in till hand tight. That is how I install the studs.
Steve
Then for the nuts and washers I use their assembly paste on both.
Steve
