art carr converter - only 3k street miles
6fire
Nice street converter - Art Carr non-lockup. This converter has 3k easy street miles in a mild street GN. This is from an Art Carr 200R4 and I don't know much about it other than it measures ~11" outer diameter, seems to stall slightly higher than a stocker, and it is stamped with AC16030.
No problems with it at all, I just replaced it with a locker.
$175. Please email, I rarely check PMs: dwelle@colomail.com
What's it worth?
Don't know what this thing is worth. I will mark it down until it sells.
New price: : $150
Sent you an email regarding a few numbers that may be stamped on the converter that will tell Art Carr what stall it is.
If you can find out if it has anything stamped on the converter, I'll check back with them.
Thanks,
What stall did you replace it with? does it run the same ,better or worst than what was in there?
Right, I got that. But I talked with Art Carr and they said there should be a 2 or 4 digit number other than that one on the converter that will tell them what stall it is. Was just curious if this converter had that or not.
