ASK CHUCK
hey chuck....do you have the article with your car in it? I think it was gmhp or car craft?
ive only seen the first page would like to read the whole thing if you have it?
thanks either way
I'll look to see if I have a copy.....
I got a question for chuck ...how long can cleaned injectors be shelved ?
Hey chuck,
How do you know you’re not crazy and just hallucinating your whole life?
I use a lube mix, and pump it thru the injs, before I cap them off.
I then put each one in a ziploc baggie, then bag them , again.
I've had them sit for over a yr, and show no issues.
I've also seen mfgr lubed, new injs, stick shut.
A major issue can be avoided by leaving them bagged, until just before installing, and starting the engine.
I bought a vac seal machine, used for food. I have a set to do, today. They'll be vac packed.
Scan it and post it up as a sticky. :cool:
It would be better reading than most of the others.... o_O;)
Just my .02, I'd like to read it. :)
Thanks Chuck!!!!
