turbofish38
Le Pétomane
- Dec 3, 2002
and the motors are the weak link. The plastic cogs get eatin up by the metal worm drive gear. You'll know when it starts to fail because it will get a loud rat-tat-tat-tat noise going every time you attempt to open or close the unit.
There is no plastic in the Astroroof motor/drive. It's all metal. Either the motor burns up or the teeth on the cables get rounded off from excessive wear. Or the cables just break all together. IMO the cables are the weak link.
And yes, it's the same unit used in the 79-85 GM E-Body.(Riviera,Eldo,Toro,Seville).
