ATR stock cat, fake battery and kit, adj wastegate
Monte231SS
Predator seeking its prey
I have a hi-flow stock replacement cat i bought from ATR quite sometime ago. It was only used to pass emission testing and 1 time at the track. Car went mid 11's with this thing on. Cat even has the four bolt flange that will bolt right up to your stock exhaust. $55 shipped
A/C Delco fake battery with green eye. This was a real battery that was gutted. It weighs practically nothing now! I'm throwing in a battery to trunk kit that consists of battery tray/hold downs and enough positive wire to run up to your starter. $55 shipped
I have one last adjustable wastegate actuator. This is pretty much still new, even has the gold colr to it still. Someone welded a piece of steel to it by the bolt holes. Probably to run it on a TE series turbo but you wont even see it once its bolted up. $50 shipped
Fake battery and trunk relo kit
Adjustable wastegate
Interested in ATR cat. What is the inlet and outlet ID? Do you know who manufactured the cat for ATR?
Ken, the opening is 2 1/2... a stock downpipe slides into it perfectly. Same for the other side but has the four bolt flange that is more oval. Overall length of the convertor is 18 1/2 inches. Its a direct fit, i didnt have to cut or modify anything to make it fit on any of the turbo cars i have owned. The convertor has PFP (Products For Performance) stamped on the shield so im guessing that was the manufacturer of this unit. I bought this from ATR back in 1993 when i purchased my first GN so i dont remember much. It also has a manufactured date stamped 10/92 of when it was made. It is a great cat, i was impressed how it flowed.
Monte231SS
I"ll pass on the cat as I was hoping it would be 3". Thanks for the information
Prices reduced! Cleaning house before the snow flies :eek:
$40 shipped for the cat
$40 shipped for the battery and kit
$40 shipped for the adjustable wastgate
