Auburn Vs. Eaton
Evaddave 87gn
Always learning...
Okay looking to hear from people that have used these different carriers. Not interested in second and third hand accounts.....
Looking for pros and cons of each.
I will be ordering a 30 spline unit within the next couple weeks.
Get a new Eaton. Don't get used. I have broken 2 Auburns, one regular and one "pro" series. I also broke a used Eaton. I run a new Eaton in my 8.5 10 bolt and I can tell you it is much beefier than the used Eaton I tried. Get the special bearings too, the part numbers should be listed as recommended when you buy the carrier.
USE AN EATON CARRIER! AUBURN USES A CONE STYLE CLUTCH. IVE SEEN THEM SELF DESTRUCT!...EATON USES A FRICTION AND STEEL PLATE STYLE CLUTCH LIKE THE FACTORY..MY PERSONAL EXPERIENCE!
i have a full eaton setup with the good bearings and it's a beast on the street :) I was told by countless people to go with eaton so I did.
Just had an Eaton unit put in mine, did 28 spline Mosers during the original build up.
Haven't had it on the track yet but I roll raced a big block, supercharged, NO2'd up, purpose built Nova last Friday night on the way to a cruise in car show, poor little guy........:D ...... Never stood a chance.
He had at least 5 excuses when we met up at the show later.
The rear end felt GREAT!
Eaton here. Randysringandpinion.com He has everything you will need
I had a feeling you were one of those types.:eek::D
Charlie, if I'm around and you somehow drop your keys, well, you'd better kick 'em all the way to the car......I'm jus' sayin'.....:eek:o_O:D
I used Amsoil with the GM additive.
I guess I'm the only one running an Auburn with 30 spline Moser's. Not a single problem in 15 years. Not like the old stock posi.
Should be noted, mine is Not a drag car.
Nope, your not alone. I've had my Auburn unit for 16 years with moser 28 spline axles and not one problem and also it's just used in a street car with regular store brand gear oil and posi additive. If i remember correctly i paid $250.00 for the unit from Jegs in 1996, money well spent i think.
Detroit Locker!
Just kidding - I've got an Eaton here also.
Friend of mine just bought a WS6 Trans Am with a Locker - wow that thing is noisy!
