The Vega is a 74. I noticed that the vega flywheel will bolt on to the back of Buick crank. I have pretty much everything to do the swap. I was just wondering about balance problems. The trana I have is from a 4 cyl S-10. Everything will bolt together. Right now I have the motor disassembled so having it balanced wouldn't be a big deal.
thanks
I think I have seen you before on Pennocks fiero forum, too bad your loosing the Duke...
anyways...
That 4cyl T5 wont last very long, especially if you get into 8+ lbs of boost. it will blow 3 & 4 out. I can show you the pictures if you need hard evidence.
But I know what your after, The chevy LUV is oddly close to the vega in dimensions, sooo heres what you want.
Im not sure on your flywheel, first time ive ever heard of the vega one swapping over.
Being that you will be using a BOP bell, you will need to use a different throw out fork - i tossed it and went with a hydralic unit. works better I think.
The T5 out of a V8 camaro is perfect, but will require some mods to make fit your shifter location.
Use the tailshaft assembly from the 4cyl trans, you will need a special adapter to relocate your speedo gear on the output shaft of the camaro T5. I have a few left in stock.
If you dont swap out the trans, I have the correct clutch disk that will accept the 4 cyl spline and still be 11" I wont need it since I moved up to the camaro T5.
good luck!
A.j.
