Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
I bought a used throttle body off of a 4.6L Ford Crown Victoria. Removed the excess material that isn't needed like the TPS and also shortened the opening for ground clearance. I then fabricated a flange to weld to the exhaust system and to provide a place to mount the throttle body. I fabricated a bracket to attach a stock Turbo Buick wastegate actuator so it would open the throttle body as boost rises. After completed and installed, I ran a boost pressure line up to the intake so it would get a boost signal so it would open while under WOT. It's really a simple idea that works. Back pressure in my exhaust dropped to near zero from 3psi....not a whole lot since I'm running a 3" system but with a more restrictive exhaust system it would work even better.
It's quiet until you nail the throttle and best of all...it's totally automatic.
Video of it working off the car.
