Anthony P
sharing knowledge with those who care to listen
- Jan 24, 2007
Federal Mogul/Moog has an inventory control/quality control problem with the Moog K6421 Problem Solver bushing kit for the front, lower control arms - front and rear bushings.
This upgraded bushing kit is supposed to contain 4 bushings as pictured below - one of each size for the driver's side and passenger side.
what has been received on 4 different orders by me and another TB owner is pictured below...
One random bushing? Moog "guru's" chassis tech support confirmed the product kit has not changed - has to contain all 4 bushings so both sides can be done. Thinking it was a one-off event, replacements were ordered only to get the same result.
Even though these parts were ordered through Advance Auto parts, it doesn't matter as the Moog parts are drop shipped directly from Federal Mogul, 2100 Midway Lane, Smyrna, TN - all orders shipped from this location. All have the same date code 1518277-P which translates to a production date of 151st day of 2018. So I conclude this whole batch is crap.
I did inform Federal Mogul corporate of this problem and am waiting for a call from the Smyrna, TN location. Told them I have no confidence in their products until they address this matter. Why would I potentially waste more of my time fixing Federal Mogul's problems if I order the K6411 kit for the front uppers or four K6178 kits to do the rear or any other chassis or steering components if they can't even correctly supply a simple bushing kit?
It is pretty sad to have to explain to the Advance counter reps that a label noting contents are 1 kit means more than one item. only when a customer is pleasantly convincing enough to get them to pull the part info on their computer to see what it is supposed to be do you get anywhere. and at first their only solution was to re-order the part again when it is clear there is a problem with the inventory at Federal Mogul.
