TIMINATOR
- Jan 26, 2020
I have a 3.5" plastic MAF and an AXIS tuner/translator, with the proper programmable "chip," my question; is the programmed and "learned" memory permanent until rewritten, or will it need to relearn if the computer power is interrupted?
It has run perfectly when hot and "learned." Once in a while, then upon restart it runs like crap until the engine is at operating temp. Keep in mind, l live in Phoenix,AZ. and it's been over 105-110 outside, and 90 in my shop.
I have disconnected the battery due to doing some welding on the car, but I am wondering if it's that or there is an issue with "cold" start (if 110 degrees is "cold"...).
I couldn't find any info either way in my instructions,(version 1.0).
It has transition issues (lean popping) on free Rev, unless it's done slowly, especially when "cold."
Ideas, experiences, answers?
Thanks!
TIMINATOR
Thanks!
TIMINATOR
