SignUp Now!and it would have to be cheap and still be driveable when I get it
I know your pain all to well! To many cars! Not enough space or wifely permission!![]()
That's been my problem - too many projects! The wife problem fixed itself. Now I store one of my GN's in my ex-wifes garage.That freed up the space to start this project.
The projects are this '82 GN, the '83 T Type I bracket race, an '02 Regal GS daily driver, and a '96 Diesel Ram. The '02 GS has gotten the attention lately - I installed headers and then found the intercooler was leaking coolant into the intake. Been goofin' around with that for the last month. And now my brother gave me his 1992 Olds 88 - it has a 3800 V6 but needs lots of work before I let my daughter drive it (she starts driver's ed in two weeks!). Plus everyone I know wants me to fix thier crap cars too!
Here is how long this '82 GN start waiting it's turn:
Time flies when you're fixing broken cars.![]()
did the 82's come with the 350c ? what gearing do you plan to use?Still looks pretty much the same, but I have made progress. Spent hours and hours scrapping oil and goo from the frame and floorboard. Painted everything satin black. Heater core was repalced and the AC box resealed (thanks for the help Dave!) The steering column wasn't original and had issues, so that's been swapped with another from an '82 GN. The front bumper had a steel reinforcement - happen to find an aluminum one at the junkyard (which is why the parking lights went from clear to orange in the above pictures). Added the missing body bushing at positions #3 and #4 (#7 still to come). Rustwise, the underside is great - tanks to all that oil.
Found good wiring harnesses. I had planned to go with 1983 wiring and ECM in order to use the newer knock snesor, but they are subtle differances that make it complicated. I'm going to go with 1982 ECM for now. It works with the 350C trans to provide lock up in all gears at WOT.
Speaking of the 350C - here it is! Back from Trans Pro in Lansing, IL
View attachment 196300View attachment 196301
Stayed with the lockup. That's a 10" 2800 stall converter. 5 clutch direct drum. Shift kit. Deep aluminum pan.
Time start putting things back together!![]()
thats good news I plan on trying to use a 4.1 in mine as well if I can find oneSo my plan on the engine was to get a decent running 4.1 out of a LeSabre or whatnot and use it as is. Finally came across a good deal a couple of years ago. Complete 1982 4.1 motor for $400. Plus the seller has a shop and is into Buick V6's. So I added a few things - new rings & bearings, ported heads and roller cam. Also installed a new timing cover, PF-24 oil pump cover and turbo intake that I already had. Yes, it still has the stock 4.1 (non-turbo) pistons. I discussed it with the builder - he has the same pistons in his SFI 4.1 engine and run 11's, so I'm going with it.
It's not staying black. Most 1982 turbo engines I have seen are silver. That's boring. This one is going to be Buick red.![]()
