Well got the car running again. Took it for a spin around the block. Came back and coolant is comming out of the over flow. Coolant looked preatty dirty so i flushed it. Swapped the thermostat with a factory 180, new cast housing, and coolant. Filled it up and it seems as if the thermostat isnt opening. Radiator gets hot but both hoses feel very squishy.. No coolant temp gauge to check coolant temp. And i dont know how to use thr power logger if it even has the capability. Also when i squeeze either upper or lower radiator hoses i head gurgling in the over flow.. Like the cap isnt seating right?
