Phoenix-MN
- Oct 22, 2008
Hey guys, (sorry for the long post) I need to pick your brains, this isn't a turbo but the basics should still apply.
I have a NA 3.8 installed in a Porsche 914
It was balanced at a presumed good shop but is no longer in business (balancer, crank, rods, pistons, flywheel and pressure plate). It idles smoothly up to about 2000 rpm and then starts to vibrate badly, shakes the whole car and you can see the steering wheel vibrate. I've tried stock motor/transmission mounts, stiffer stock style mountss and currently HR poly mounts. Vibration levels are the same for all. The engine is built up like this:
3.8 NA .030 over
9.5:1 flat top pistons
Lunatti BM II cam
Harland sharp 1.65 roller rockers
Cloyes double roller timing chain
Holley intake
Holley HP EFI fuel system (also controlling spark)
Shorty headers
I've taken off the drive belts to eliminate any accessories that might be causing the vibration and it doesn't help. The balancer bolt is torqued properly. The vibration is there sitting still clutch engaged in neutral or dis-engaged in neuitral or in gear. Same for driving/moving down the road. I've run out of ideas and am begining to think that it was not balanced properly to start with.
Anybody have any thoughts on what else to check?
Paul
3.8 NA .030 over
Lunatti BM II cam
Holley intake
Shorty headers
Paul
