DonnieShort
Who's Next?
- May 27, 2001
Reason I wonder is I still had the stock springs on the car ( 87 GN ) and the car leaned bad on the driver side back. Front was real good, but the back was very noticable. I put new progressive rate sptings on and it closed the gap from almost an 1½" difference to 5/8ths. I have UMI tubular lowers and Full Throttle's big bar but the uppers are bone stock. If the uppers' bushings were bad or the upper itself tweaked some would it make the car lean to one side? Car makes over 606hp to the rear wheels and since I did the motor I can't get it to 60' for nothing as to before it would 60' in the 1.54 - 1.56 range. I know that the body mounts can cause this too but they seem to be in good shape and this problem kinda just gradually kept getting worse. One thing to note is when the car launches ( if you are looking at it from the back ) the back of the car kinda slides over to the right. Check it out, it's the top left video ( Donnie Short's GN ) http://www.maftpro.com/videos.shtml
Thanks!!!
Thanks!!!
