Baer SS+ rear 9" brake systems (new)
WHITE T
Baer Brake Systems
Guys,
I have a brand new Serious Street + (SS+) rear brake system for a Torino bearing 9" rear. System was mounted to the 9" rear, but never used.
This system includes calipers (upgraded to a black anodized finish), pads, brackets (act as bearing retainers), 2pc slot, drill, zinc plated rotors and hardware.
Hats are currently drilled for 5/8" studs. If you dont have large studs, I will change hats to new standard size holes.
System does not have park brake, and does not include hoses.
Rear system looks like this Baer Brake Systems -- Gallery: SS+ Rear -- Performance you can See!
Lists for $1195.00 (with the 2pc and caliper color), selling for $650.00 + shipping.
I have this listed on another site as well, so first come first serve! :) Will have pics this weekend
Thx!
Installed new hats (no more 5/8 studs) and now has park brake.
On e-bay Item number: 170513770488
Thx!
Rick what would be needed to convert this to fit 8.5" GM instead of 9" ford???
To be honest... not exactly sure.
We never offered the smaller SS+ system for the G-body rear. I am not sure if the park brake will interfere with the shock (even with the shock relocation brackets, which you will need on a stock rear).... so basically I am not 100% sure if it will work.
Everything is basically the same other than brackets.
thx!
