Dusty Bradford
- May 24, 2001
I don't see a 224/224 pulling very well above 7,000 rpm on 274ci.
SignUp Now!Motor is 9.5:1 compression and the can is a 224/224 with 112lsa. Nothing exotic
As for peak torque, when cal was here doing the tuning we had to abort the last run because my fuel pump couldn't keep up so I do not have a perfect No. But it was still pulling hard and the slope on the dyno sheet was still increasing steeply at 6100 rpm for both hp and torque.when at the track I feel it still pulling at the higher rpm. I know for certain it pulls hard up to 7000, does it pull hard from 7000-7500? That's hard to say, but when looking at the mph and driveshaft speed on the log, they are increasing at the same high rate.
If I am out of compressor I would have to step up to a 88mm or something wouldn't I? Going to a larger 1.44 A/R wouldn't do anything if this is in fact a air consumption issue and not a back pressure issue, correct?
Your boost changes are directly related to your rpm. As rpm goes up so does the BP. On the gear change the RPM drops and so does BP.
Hey Chuck. How are you?Hi Ralph!!![]()
What 76 are you running, Billy?
Our setups are not far off of each other. But I don't see a 224 cam making power past 7,000rpm. Have you played with your shift points? Like shifting the car at 6,600rpm from 1-2 and 6,600rpm from 2-3 and letting it ride out the back door? Just curious, what ignition system are you using? and what plugs and gap are you running? Your spark can also be limiting your potential. 28psi is about the limit I can get out of my MSD Digital 6. I would need something much stronger like a 7 series to allow me to throw more at it, but for my purposes and the amount of driving i do on the street, The MSD Digital 6 suits my needs.
Or at least the lobe numbers and LSA. May look like 3192S/3192S R112I called Comp this morning and received my cam card from them. Is anyone still interested in knowing the specs?
Yup. Are you running this as a solid or Hydraulic ? I think you would do better with the 224 3192 lobe on a solid FWIW. The 3192 lobe after being ground on a Buick core will be about as aggressive as a really good solid roller cam would be and has a lot more area under the curve for more flow.4871S /4871S R 112.0
Is this what you are looking for?
224/224 cam
LSA: 112
Intake centerline: 112
