hello everyone,
a good friend of mine from this site told me that alot of you have gotten some really good results from using BeeHive style valve springs. I have used alot of tips,advice and parts from this board so I once again ask for your help. I am not familiar enough in the area of valvesprings so this is where I need your help. My cylinder heads(Trick Flow Track Heats,read Ford) require this spring. CompCam part number 986-16 and here are the specs.
OD= 1.430
Coil Bind=1.150
Rate=296
ID outer spring=1.070
ID inner spring=.697
my camshaft has a max lift of ~ 565i and 575e.
Any help appreciated.
Edward
OD= 1.430
Coil Bind=1.150
Rate=296
Edward
