b4black
- May 24, 2001
I've been meaning to post this for sometime. It's 103°F outside, so I I just found some time.
I have too many project cars, so my '83 T Type basically only comes out of the garage to do some bracket racing with a Chicagoland GSCA Club a few times a year. And since it is bracket racing, I can't mess (aka tune) with it too much. First time this year we took both cars. My girlfriend races my '02 GS and I drive the '83. First run of the day.....(GS left, T Type right)
Best times for each car! The T Type ran very strong all day, but did slow a little as the day warmed up. Several others runs were in the 14.2's. Best day ever with the car.
I usually run 100 unleaded race gas, but the local station quit carrying it, so this was on 112 leaded. It still knocked some. About 5 leds will light up randomly on the Casper's gauge (it's always done that). Boost would briefly get to 19 psi, but most of the time, it's somewhere below that. (The wastegate isn't opening - I should go back to the stock turbo for now.) I later found out the alcohol injection had become disconnected over the winter. I know I run too rich and I have been trying to dial back the alcohol anyway. Without any, the car leaned up some and ran strong - and consistent. I made it to the semi-finals before the rain came.
The GS by the way runs on 93 pump gas, has an intercooler and 3.2 pulley. Scan tool showeds zero knock, so now it has a 2.9 pulley, and I ran a 14.02 in the heat last weekend. The pulley is about all that I change on this car. Easy!
And that is the approach I am going to take with the '83 for now. Leave the alcohol disconnected, run just 93 pump gas, leave the carb alone, dial back the boost, don't pull any timing with the MSD, and get rid of all the knock. Then gradually work my way back up. One thing at a time. No more juggle alcohol, boost, timing, A/F, octane, etc.
I also put a wide band O2 sensor in. Even without the alcohol, it's very rich - 10 to 11 A/F at times. At 9 psi, it still knocks some. So I disconnected the wastegate and left it open. Still knocks. It's not false knock. It seems to happen just as the secondaries open. I need to do some more driving around to confirm.
I'll keep everyone posted on what I find out. It might be a little while though before I can get at it again. The starter solenoid needed a whack the other day to get going, so I need to fix that before venturing out again.
