Best 60ft on drags!
I have never used them, but I have heard people getting 1.7xx-1.6xx on drag radials. If you really want a good 60' time, get slicks.
slimm
With Nitto's I usually run around 1.77 to 1.81 with a best ever of 1.72.
I'm sure I could do better if the Nitto's were on 15x8" rims instead of the stock rims, but ya make do with what ya have.
MT ET Drags 26x10 I have had consistent 1.6's with a best of 1.61
60's
I had a best of 1.62 on Nittos:D
And a few high 1.6x's. Its all in the track prep.
Jeff
I got a set of Centerlines rims and a set of BFG's 275/50/15 Drag radials.
I've gotten a string of low 1.71 and 1.72 60ft times on heavily worn 245/50/16 Nitto DR's. Need a smokey burnout and 18psi pressure when hot.
I've only run 26x8.5" slicks once with low boost launch (5psi) and a 1.70 60ft time.
With practice repeatable 60fts times in the 1.70's should be easy. With the Nittos brand new I pulled off some low 1.8's and then a best of 1.78 with only 500 miles on them. The more worn the Drag Radials get... the better they get.
-GNX7
With a massive, fill the car with smoke, burn out and no hop I got consistant 1.62 - 1.63's with 255/16 drag radials @14 PSI. When I got to the strip I just drove right on (I drive to the track) and at 35 PSI and a little ditty burnout I got a 2.68 and spun into third. The drag radials really hook with low pressure.
