T
TTA89
Guest
Re: downpipe
Ill go after this one...
The only reason you felt improvement was you took off the Cat at the same time. If You would have spent $30 bucks on a Testpipe instead of $500 on a downpipe you would have gained the same performance.
Your analogy with the straw is correct, only you need more air than a straw can provide, in the 12 second Range a TTA doesnt need anything bigger than a stock crushed downpipe. Its not hurting performance. The downpipe sure looks like a restriction but you what, Its really not. The engine just doesnt seem to flow enough air to really care about that.
But the pipe looks impressive and people at the track go "Oooooo look at that downpipe"
Originally posted by mrtransam3
I have a TTA and the biggest bang for my buck was the terry houston head with the 3 inch mandrel bent down pipe and removing the convertor. I also help my friend with his 87 GN and BOTH of the stock downpipes are extremely restrictive. The one that came off my TTA was crushed almost in half where it passed the frame rail. That was GM's solution to elimanating exhaust rattles! If you think it's not holding you back, but you fingers over your nose and try breathing through a straw and then you will know how your engine feels. After all an engine is just one big air pump. The more air you get through the more power you make!![]()
