Best (Cheap) OBDII Scanner
84GNTTYPE
Senior Member
Looking to get an inexpensive OBDII scanner to pull SES and ABS codes and erase them.
I've see both Actron and Auto X-ray models for about $150. Are they any good? Anything better or cheaper that I should be looking at. Definitely don't want to spend more than $200 . . . it's just for my personal use.
I seen a scanner at Wal~Mart that looks pretty similar to my Actron. Reads and erases codes for slightly less than $100 you may wanna check it out?
Don't laugh but you can be on your way for less than $50. Look at this . That one is considerably less expensive than this one but it looks to be about the same, no frills device. I bought the same one as the $45 unit a couple years ago on eBay (cost about $30 then) for our Expedition and it works great and will do just what you're looking for.
