Aeromotive Eliminator should do the job also. Just be sure you have an electronic pump controller to slow the pump down when it is not needed and be sure the supply/return lines are up to the task. I have been running Aeromnotive pumps for several years now and have had good luck when starting with a new pump or known good pump. Just don't starve them for fuel. Running dry is deadly so you WILL need to position the pump below the fuel supply. There are some pumps that can survive that...I think Fuel Lab is one of them...so watch your fuel system design carefully and pick the appropriate pump. FWIW, the Aeromotive pumps are designed to be immersed in fuel so they CAN be installed INSIDE the tank! Some tank manufacturers can design the tank accordingly.
Conrad
