Best HeadGaskets to use w/t 14Bolt GN1s?
  • Thread starter Thread starter LikeMy6
  • Start date Start date
L
LikeMy6
Guest
Just looking for advise from those with experience on this. 14 bolt GN1s & stageII block. I see that the Fel-pro 1026 can be used and have heard of a new gasket offered by PTE that was designed by Nascar and that someone in Orlando was using a pair running something like 40#s of Boost! with no gasket problems so far. any info??
TIA
Frank
TIA
Frank
No problem with Fel-Pro 1026s here. I think the other
gasket you're talking about is the Victor-Reinz 5957SC.
Probably 6 of one, half-dozen of the other. Take your
pick- they're both good if the deck and heads are flat.
Victor-Reinz 5957SC
I removed my GN1heads to replane the exhaust flangs and after 1 1/2 years the gaskets looked perfect. I have given them a lot of reasons to blow. Never had a problem or leak.
