HelloBozos
A Bozo in Buick
- Feb 9, 2011
When going G-Machine with a Grand National there are Many Many things you must do before buying the tires you desire.
First: an most important, Get your Body Straight on the Frame. Non these car came perfectly straight from the factory. It been a Proven Fact! There not off a lot but are enough to serious hamper your tire clearances on wide tires,change the bushing out while your there,go poly urethane or if your die hard, Hockey Pucks
Second: Plan your whole suspension at Once. Reason, all the different styles an combinations have different lowering an wheel off set's on the front,Example; one set front a-arms drops the car a inch,disk brakes set the wheel out to fender 3/4" more then stock etc.etc.
Third: Now order your tires an rims for Monster. You'll have perfect Custom G-Machine that Works!
Fourth: Buy every "Brace" you can find for G-body unless you added a roll cage,There's about 4 different sets for the front an 3 sets for the rear,You will twist an torque everything you just done back out of shape!!
Enjoy!
Enjoy!
