SignUp Now!This topic has been beaten to death IMO, but the concensous is NGK UR5's gapped around .32.
and I would look for right Autolite plug for your build and stay with this brand ONLY no matter what build /boost you have /run , that's my opinionThis topic has been beaten to death IMO, but the concensous is NGK UR5's gapped around .32.
I'm still wondering about iridium plugs. Most new cars come with iridium. Denso recommends ITF20 gapped .035.
I know platnium won't work in our cars (they run too hot)_.
You should experiment. A lot of solid advice here though. The 1st reply i gave has been what ive done in all cars ive worked that ran over 20 psi in the last 12 years. For under 20 psi CR43TS is fine gapped at .035.
 ........you might be ok with others making less power but..... Autolites worked best for me all the way period....and yes ...iriduim plugs were just an experiment
nope , NOT iridium plugs guys , $18 a pop of waste money ,Bison's firts suggestion is fine , my suggestion to stay only with Autolites is based on problems with almost any brand BUT Autolite plugs , well .... at one point at dyno shop tunning my car next guy in line was an import/Mustang GURU , you know that imports will run some crazu boost # , I was blowing spark off at that dyno run with Iridium plugs gapped at 30 ,so I suggested NGK swap that I had in mycar but never got installed yet and the HIGH BOOST GURU said NOPE ...... let's get you Autolites and gap them at 25 ,well to make the story short ...GM igniton module /coils and Autolite plugs have been the BEST for me ever since ,again that's just my opinion........you might be ok with others making less power but..... Autolites worked best for me all the way period....and yes ...iriduim plugs were just an experiment
Thanks for the imput. I think I'll go with the CR42's. I like AC Delco parts as much as possible!!
how about just making it a sticky? spark plug sticky
