stripping or blasting
I've been slowly working on a full frame and body restoration on my t type.
I talked to some of the best body and paint guy around some were through business and some were friends. The first thing is do you have paint or laq finish I had the original laq finish and it had stress fractures througout the body (finish) from the Virginia cold Arizonia heat.
What most people dont realize is those crack and fractures are not only in the paint but into the metal surface also. so just sanding and primer will not remove the crackes they will come back.
Sandblasting the frame, rear axle, body undercarriage, trunk floor, engine cowl and interior floor can be done with white silica sand easly not hard and not real time consuming. Just remember to put everything on canvas drop clothes and pin the side up easier clean up and easier to collect your sand back up went through a 100lbs on 1/2 the frame after tarp 200 lbs total used.
The body can be spayed with baking soda it the new thing and the the vehicle, whole vehicle is then dipped to re-seal the body parts about $3000 in phx last time I checked
We used aircraft stripper on the body the spray and did 1 panel or section at a time sprayon let set 15 min use plastic putty knife and bondo applicator to gently scrap off finish. if the paint wont come off then wash panel let dry re spray let set once all paint has been removed wash dry inspect for damage scraps dent ding mares repair as required then hand block wet sand entire panel with 180/220sandpaper wash/ Dry
Wash-wipe entire panel with cleaning laq thinner its has less impurities.then prime.
if you leave bare over night or for a period of time wash with metal prep removes surface oxidation wash/dry. then rewipe down with thinner
We srayed the frame and rear axle with acid etch primer 3m pad then sprayed with 2part catlized PPG primer them spayed with dp Black
The body was sprayed with PPG 2 part cat primer truck floor undercarriage cowel and interior floor,interior side panels then sprayed with DP OEM Black all original codes will attach a couple of photos of some of the work and repair
s its what we did! time is the cost I only work on my car on sundays
