SignUp Now!Originally posted by lburou
I've been using an antenna made from a coffee can....
Originally posted by TurboBob
Do these things interfere with 2.4 ghz and 5.8 ghz cordless phones? I want to run some wireless network stuff, but I already have a 2.4/5.8 phone setup.
B
Turbojimmy is right about the 2.4 Ghz phones, the 5.8 phones won't interfere with the network though. I bought a 5.8 for my wife to use while I'm surfing and have had no problems since.Originally posted by TurboBob
B
Originally posted by GNandGS
hey Bob.
Im assuming these are for laptops? Actually, it doesnt matter....
There are some combos out there that come with an AccessPoint (AP) AND a wireless card (NIC).
Since you already have a router, I suggest an access point. These do not do routing and do not have additional ports (hub/switch) but cost a less also.
Im not going to tell you what is "best" as I havent tried them all. I will suggest that you:
*change the default password on any internet appliance as soon as you can
*disable remote administration. This is often the default but you do NOT want the option to configure devices from the internet.
*I prefer to change the default IP address if using static
*its a long shot anything would happen in MY area, but make sure your machines are patched if using Windows should an infected machine wardrive your neighborhood (still not likely).
*Restrict access to your wireless device so that only the MAC addresses you allow can use it. This should be a minimum.
*Logs! Confusing? Maybe. But knowing you have them can come in handy.
*Check user reviews online, but be aware of the posted dates! This technology moves quickly and firmware updates can fix a lot!
*Go to a buddies house to see what he is using, maybe even take a laptop along to test with.
*NOT required but if you dont already have the NIC, get the AP and NIC from the same company.
Im thinking of something like this:
http://www.linksys.com/products/product.asp?grid=33&scid=35&prid=608
or
http://netgear.com/products/prod_details.php?prodID=170&view=
D-link, Netgear, Apple, and several others now offer entry level solutions. Bundles may or may not be available direct from manufacturer... the resellers are often the ones doing it.
Shawn
