Aem has quality MAP sensors. I routinely use a 3.5 bar. A 5 bar is available. The most important thing is to have the correct calibration table for the sensor you are using. If you are changing sensors and check off a box for a higher output sensors you will need to re-scale your tables since the numbers in the cells will remain the same and the pressure column will change. Some sensors like the AEM have a range of .5 to 4.5v even though it's a 5v sensor. I'm amazed at the number of incorrect calibration tables that are out there. Having an accurate calibration table and an accurate sensor like the AEM is very important for data acquisition and comparison.
