BHJ balancer
bilt2run
If the outer ring on a BHJ balancer has slipped around the hub a few degrees is it junk? I have been told that this situation is normal for this brand and is of no concern....:confused:
It is not normal and is of great concern. Contact BHJ to have them re-seat it in the correct position.
What makes you think it has slipped? The BHJ balancers come with a crank referance of around 6 degrees vs the stock 10 degrees.
I should have added, if you have a stock ECM, it will not be correct, with a FAST system, you can compensate for the small difference as Cal described.
BHJ
The balancer is way more than 3 degrees off . Dave from Webber remarked TDC and it apparently moved again because his mark is now several degrees off. I am trying to do the initial start up on my stage II. BTW I am running a Gen 7. I think that I have control over those timing issues?:confused:
