tminer
Not quite normal
- May 25, 2001
I've got an Eagle crank and BHJ balancer but the BHJ hits the crank sensor before it is flush with the crank snout. Is this common? Is the sensor durable enough to use a bench grinder to clearance it?
Is there something else possibly going on to cause this? I am using the thicker felpro timing cover gasket per the DLS cam button specs.
Thanks,
Tom
Thanks,
Tom
