Someone recently mentioned to me that they had an issue with a 109 motor with a cam that was around 600 lift or a little over.....that they found the lifters to be too high in the bore causing oil to be lost in the roller area of the lifter during times near peak lift. Another words... at near peak lift... the oil galley was being exposed to the roller itself that can't seal it off..... therefore causing the oil hemmorage. The 109's oil galley is huge. I am wondering if that is the issue I am having on my 109. My lift is over .590 on the intake with the 1.65 rockers. It sure would explain alot.
One way to solve this is to bush the lifter bores and reduce the size of the opening feeding the oil band on the lifter. Another way is to not run a high lift cam I guess.....
I assume that core shift in these blocks might move the lift threshold so-to-speak before the oil would hemmorage out the bottom of the lifter. Shielded foot lifters help this but at some lift point... would still do the same.
In my case, I've tried Morrel's as well as stock hyd rollers.....both of which....I would say... the foot is shielded pretty good.
